Laadpalen in MyPOI
In dit board alles over elektriciteit voor het laden van Volvo's. Laadpalen, kabels en stekkers etc etc
jrkalf
Hier de forum archeoloog. Bij mijn opgravingen kwam ik dit topic even tegen. Het blijkt inderdaad dat die file van RichieB niet echt lekker met Sensus Connect werkt, aangezien de opbouw van de bestanden geheel anders is.
"bestand richieb"
Code: Selecteer alles
<?xml version="1.0" encoding="UTF-8"?>
<gpx
  version="1.0"
  creator="GPSBabel - http&#58;//www.gpsbabel.org"
  xmlns&#58;xsi="http&#58;//www.w3.org/2001/XMLSchema-instance"
  xmlns="http&#58;//www.topografix.com/GPX/1/0"
  xsi&#58;schemaLocation="http&#58;//www.topografix.com/GPX/1/0 http&#58;//www.topografix.com/GPX/1/0/gpx.xsd">
<time>2013-12-20T10&#58;40&#58;32Z</time>
<bounds minlat="35.823220000" minlon="-9.676430000" maxlat="63.451900000" maxlon="37.650770000"/>
<wpt lat="52.078580000" lon="5.142870000">
  <name>Snellader Herculesplein 300 Utrecht NewMotion NL-TNM-FC11</name>
  <cmt>Snellader Herculesplein 300 Utrecht NewMotion NL-TNM-FC11</cmt>
  <desc>Snellader Herculesplein 300 Utrecht NewMotion NL-TNM-FC11</desc>
</wpt>
</gpx>
Bestand exportje uit de Sensus Connect:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<gpx&#58;gpx creator="" version="1.1" xmlns&#58;xsi="http&#58;//www.w3.org/2001/XMLSchema-instance" xmlns&#58;gpx="http&#58;//www.topografix.com/GPX/1/1" xsi&#58;schemaLocation="http&#58;//www.topografix.com/GPX/1/1 http&#58;//www.topografix.com/GPX/1/1/gpx.xsd" xmlns&#58;gpxv="\VolvoGPXExtensions\V1">
  <gpx&#58;wpt lat="52.354562" lon="4.441362">
    <gpx&#58;name>HUISJE</gpx&#58;name>
    <gpx&#58;link href=""></gpx&#58;link>
    <gpx&#58;extensions>
      <gpxv&#58;WptExtension>
        <gpxv&#58;WptIconId IconId="1"></gpxv&#58;WptIconId>
        <gpxv&#58;POICategory Cat="Personal"></gpxv&#58;POICategory>
        <gpxv&#58;Activity Active="true" Level="information" Unit="second" Value="9"></gpxv&#58;Activity>
        <gpxv&#58;Presentation ShowOnMap="false"></gpxv&#58;Presentation>
        <gpxv&#58;Address ISO="" Country="" State="" City="" CityCenter="" Street="" Street2="" HouseNo="" ZIP=""></gpxv&#58;Address>
        <gpxv&#58;Phone Default=""></gpxv&#58;Phone>
      </gpxv&#58;WptExtension>
    </gpx&#58;extensions>
  </gpx&#58;wpt>
</gpx&#58;gpx>
Ik ben al wat aan het vogelen, maar ik heb nog geen goede omzetter gevonden. De zoektocht gaat door...
Weten is leuk, controleren is beter.
Heden:
2024- : Volvo XC70 2.5T AWD Ocean Race
2019- : VW Caravelle, TDI 204pk
Verleden:
2019-2023: Stofzuiger Model 3
2017-2019: Volvo v90 T5 Inscription Onyx Black Afbeelding
2014-2017: Volvo v60 D6
2010-2014: Volvo 850 T-5R
2008-2010: Volvo 854 2.5_20v
RichieB
Dat is gpx 1.0 vs gpx 1.1. Kan gpsbabel dat niet omzetten?
V70 MY2004 Geartronic 185pk
jrkalf
Het is me uiteindelijk wel gelukt om een standaard GPX file in te laden, het bleek dat de gpx files bij mij niet in een juiste plek stonden en daardoor liep het niet lekker. Heel stom.
Verder gaat het mij even om het GPX:GPXV stuk. Dat is dus een specifieke extensie die Volvo er heeft ingebouwd voor zichzelf.
Hoe heb jij dit trouwens gedaan met het icoontje richie? Ik heb namelijk nog niet in Sensus Connect gevonden hoe ik dat verrekte BMP icoontje kan importeren. Het lijkt er op dat dit een gesloten systeem is dat door Volvo alleen toegestaan wordt voor een select aantal items, zoals bijvoorbeeld:
- Volvo Dealers
- BP
- Mcdonalds
- Tango
Heb je een idee?
Heden:
Verleden:
RichieB
Ik heb geen Sensus Connect, dus ik heb geen idee.
rkollman
Hier ook nog steeds problemen om een eigen icoon te hangen aan geimporteerde laadpalen van www.oplaadpalen.nl
Ik probeer dit in een Sensus Connect, Volvo PIH MY2015.
Ook kon ik gisteren nog een aparte categorie aanmaken (dus naast de standaard "Anders", "Prive" en "Werk") maar als ik dat nu doe, kan hij er niets meer mee. Bugje of heeft iemand dit probleem ook al eens gehad en opgelost?
Terug naar “Elektriciteit voor Volvo Electric Vehicles”
