Toekomst
Geplaatst: 05.09.2007 - 13:44
door Ben
Automotive News is dishing on Volvo's product lineup plans between now and 2010. The newly released second-generation S80 won't see any major changes, nor will the new 70-series wagons, the C70, or the C30. The S40's going to bid us adieu, as there's price overlap with the S60, and the S60's not much larger than the S40. The C30's going to serve as the entry-level Volvo, while also angling at MINI's territory of cutieified premium small cars. The S60, while handsomely drawn, is becoming long in the tooth. A redesigned S60 will bow in 2010, and it will be smaller than the current model in an effort to differentiate it from the S80, as well as still serve those customers who would have gone for the S40.
While Gothenburg's losing a sedan offering, it'll be adding a CUV in early 2009 when the XC60 hits the streets. With the CUV market currently on fire, a smaller Volvo 'ute to go after X3 shoppers is a shrewd move. The basic hardware's already been piled together as the Land Rover LR2, which we suspect offers a decent preview of the XC60 experience. Basically, what we see happening is the phasing out of the P2 platform that Volvo developed in the '90s for the original S80, and a migration of all vehicles to some flavor of the EUCD platform.
Bron: Automotive News - via Autoblog.com
Geplaatst: 05.09.2007 - 14:16
door eXite
Wat een vreemde keuze, om de S40 te laten vervallen. Ik heb juist het idee dat de S40/V50 serie de meest succesvolle serie is die volvo ooit heeft geproduceerd. (of de V70, een van beiden)
Geplaatst: 05.09.2007 - 17:01
door lancer
Valt wel mee, de S40 en S60 worden vervangen door 1 model. Een veelgehoorde klacht is da de S40 iets te klein is, gezien het aankoopbedrag (prijs van een passat, formaat van een golf). De S60 is niet zo gek veel groter, dus.....
Geplaatst: 05.09.2007 - 18:09
door coyote1980
Komt er nou ook nog iets van een nieuwe V90?
Geplaatst: 05.09.2007 - 18:40
door bart simpson
Skip je een S60 ten koste van een grotere S40 zul je mogelijk toch weer een kleinere sedan in het programma op moeten nemen, een wat grotere S40 is nu niet direct een opvolger van de 344, 460, S40/544 series.
coyote1980 schreef:Komt er nou ook nog iets van een nieuwe V90?
De nieuwe V70 is wel "groter" dan een V90 ooit was, 11 cm breder, 9 cm hoger, wielbasis 5 cm groter maar wel iets korter door de dwars geplaatste motor, hij is nu gebaseerd op de S80 waar de vorige nog op de S60 gebaseerd was.
