Iemand ervaring met Gazer producten?
crashingdutchman
Ik gebruik Sygic als navigatie tool op mijn telefoon in mijn Volvo V60 uit 20111. Nieuwe functionaliteit van Sygic is de mogelijkheid om via Mirrorlink het display van de telefoon op het scherm in de auto te tonen. Volgens mij is dit standaar niet mogelijk op mijn auto vanwege geen ondersteuning van MirrorLink.
Ik kwam toen deze 2 producten tegen op de website van Gazer in Engeland:
- [target=VI700A-SNS7]https://www.gazer.com/uk/interface/intf ... 700a-sns7/[/target]
- [target=VI700A-SNS7]https://www.gazer.com/uk/interface/intf ... 700a-sns5/[/target]
Ik kon op het forum geen vermeldingen van deze apparaten vinden, maar misschien is er toch iemand die er bekend mee is. Dan zou ik dat graag horen. Misschien zijn er alternatieven.
The key advantage of Gazer VI700A-SNS7 multimedia interface is that you can install in your car while keeping the stock head unit fully operational. The stock head unit in your Volvo is maximally adapted to the sound system available in the car and to the car itself. The car stereo operates as one with the car. It is connected with other electronic systems via CAN bus and is responsible not only for audio playback but partially serves as the central node of the computer-aided car management system. It is therefore highly inadvisable to replace the stock head unit in Volvo vehicles. However, with Gazer VI700A-SNS7 multimedia interface, you can significantly expand its functionality and turn it into a full-fledged multimedia center that will make driving experience much safer and ensure that both the driver and the passengers feel as comfortable as possible. All the stock functions, including FM radio, SD and USB playback, Bluetooth, audio settings menu and car functions customization, will remain intact and operate just as Volvo intended.
It takes only one press of a button to connect Gazer VI700A-SNS7 multimedia interface to your vehicle's display or audio system. In addition, the driver gets several extra safety options: ability to plug in rear and front view cameras, Gazer surround view system with DVR and CCTV functions, and plenty of other useful features.
The GPS navigation function will allow you to plot a route and to get real-time information about traffic jams when Internet connection is available. Full support of in-car screen mirroring for iPhones or Android smartphones along with touchscreen controls on the car’s display unit will offer you far more functionality than Car Play or Android Auto modes: unlimited capabilities that can only be compared to using a tablet PC or a laptop, which is completely integrated with your car. Furthermore, to make the time spent in a parked vehicle thoroughly enjoyable, one can connect two additional audio-video devices, such as a digital T2 TV tuner, a DVR, an external DVD player, and even a Play Station game console or a karaoke system.
Alvast hartelijk dank!
Laatst gewijzigd door crashingdutchman op 01.01.1970 - 01:00, 1 keer totaal gewijzigd.
Volvo V60 2.0D 2011
Volvo V50 2.0D 2006
Volvo V70 2.5D 1998
Renault Megan Scenic
Alfa Romeo 155 2.0 TS
Alfa Romeo 33 1.8
Alfa Romeo Giulietta 1979
360Degreez
Idee : +1
Uitvoering : -1
Dit soort boxjes komen al heel lang voorbij en hoewel ze anders beweren is er nauwelijks sprake van integratie. Het apparaat kaapt simpelweg het beeldsignaal weg en toont zijn eigen output.
En dat is prima, maar je mist al je meldingen en instellingen zoals de stoelverwarming, volumebalk, audio-settings en klimaatinstellingen waardoor je eindeloos aan het heen-en-weer switchen bent. Daarnaast moet je auto bij dit model specifiek voorzien van Sensus Connected Touch (met touchscreen). Waarschijnlijk omdat ze geen moeite wilde doen om een eigen Android-skin te maken en de controls van de auto door te zetten via een eigen applicatie.
Bovendien is de hardware traag en draait het een oude Android versie waar straks een hoop apps niet meer op draaien, inclusief screen mirroring. Enne.. als kers op de taart hoef je bij dit soort fabrikanten ook geen updates te verwachten ;-)
Ik ben ook niet blown-away met de features van de "High Performance" audio, maar ik ondervang alles gewoon met een smartphone op het dashboard en bluetooth streaming :-)
teebee
Sygic?
Vind ik buitengewoon intuïtief... <NOT>
Ik kan er in het geheel niet aan wennen ondanks dat het al flinke ‘verbeteringen’ heeft doorgevoerd.
evert65
ik heb sygic op de vrachtwagen
en sta er van te kijken welke omwegen dat ding soms verzint
meestal weet ik de weg wel, en draait sygic op de achtergrond , en bij onbekende locaties heb ik soms voor de seuriteit google maps er naast draaien, dan sta je wel eens tij kijken naar het verschil in km en tijd
affein, als jij er blij mee bent , gewoon blijven gebruiken hoor
