ES90
Geplaatst: 16.02.2024 - 16:34
Volvo Cars is working on an electric version of its luxury saloon, which will probably launch in 2025 as the ES90. According to media reports, the carmaker has already built the prototypes at its plant in Shanghai. Deliveries will kick off in mid-2025.
According to information from the specialized site motor.es, the Volvo ES90 will be based on the SPA2 platform and come with one or two electric motors. The battery will be rated at 111 kWh gross or 107 kWh net, allowing for a more than 600 kilometers range.
More room on offer
The electric version will be slightly larger than its ICE counterpart. It will be 3,5 cm longer, 6,5 cm wider, and over 10 cm higher. Looking at the increased height and a wheelbase that is also 7 cm more, the ES90 will offer more interior room. The all-wheel drive version of the ES90 weighs around 2 600 kg, and the single-engine variant is said to weigh 2,5 tons.
Internally, the project has V551 as its code name. The ES90 (with this name, likely) will be available in China and Europe, but its biggest market will probably be the US.
More room on offer
