Wat is dat voor ding?
Voor kenners: de "Roffel"
mga1600
Rechts in de kofferruimte van mijn C70 Cabrio zit (achter de bekleding) een soort met rubber bekleed blok van een cm of 10 lang. 7 cm hoog en 3 cm dik. Het zit met rubberstrips vast in een behoorlijk zwaar uitgevoerd stalen frame. Ik zie geen enkele electische verbinding o.i.d. en vraag me af wat het is. Iemand een idee?
XC60 T6 Ultimate Dark my24
heerhugo
Is het nummer 14 ?
Zo ja dat is dan de 2de antenne van het Diversity systeem.
System overview
General
Note! The components included in the audio system depend on the market and on the equipment level specified by the customer.
-Radio (1)
-Dolby unit (2)
-Six-disc CD changer (3)
-Amplifier (4)
-Power antenna (5)
-Bass speaker (6)
-Treble speaker (7)
-Mid-range speaker ( 8 )
-Bass speaker (9)
-Centre speaker (10)
-Treble speaker (11)
-Balance filter (for door speakers) (12)
-Sub-antenna in bumper (13)
-Signal booster (for sub-antenna) (14)
Wiring
The wiring for all audio system components is preinstalled and integrated in the ordinary wiring harnesses
Radios
The radios are of the 'wide front' type and are available in two main versions:
-a single-disc CD player (SC-805, 816 or 836 depending on market)
-a CD player with a 3-disc magazine (SC-900 or 930 depending on market)
Amplifier
The amplifier is mounted on a bracket in the boot.
The amplifier is available in two versions:
-4*60 W (to match SC-8XX)
-4*100 W (to match SC-9XX)
Antennas
The C70 is provided with two antennas as standard equipment, a main (power-operated ) antenna and a sub-antenna. The sub-antenna is mounted in the rear bumper on the right-hand side and is provided with a signal booster mounted in the boot under the right-hand rear light.
On cars with RTI, the sub-antenna is used by the TMC/FM receiver for RTI. The sub-antenna has no function in cars without RTI and with an SC-8XX radio. Both antennas are connected to the radio in cars without RTI and with an SC-9XX radio.
The SC-9XX radio features a diversity (two-antenna) system. The radio signal reaching the receiver is passed through a multipath detector which modulates it to an intermediate frequency. The detector senses if the signal is affected by interference and, if reception with the main antenna is poor, transmits a control signal instructing the system to switch to the sub-antenna. This enables the radio to deal more efficiently with multipath interference.
Loudspeakers
1" treble speaker in dashboard
8" bass speaker and 4" mid-range speaker in each door The signal to the speakers is balanced by means of a balance filter mounted in the door.
8" bass speaker and 1" treble speaker in parcel shelf.
Centre speaker and Dolby unit (Dolby ProLogic Surround Sound system)
Only the SC-9XX radio is suitable for this system. Note! Cannot be combined with RTI. The centre speaker unit consists of a 4" bass speaker and a 1" treble speaker.
The Dolby unit divides the normal stereo sound into several channels (this function is described in further detail on page 18 ).
Six-disc CD changer
Standard/option/accessory depending on market.
The CD changer is mounted in the boot on the same bracket as the amplifier.
Component/equipment level0123
SC-805 EUX
SC-816 US/CDN/AUSX
SC-836 JPNX
SC-900 EU/US/CDN/AUSXX
SC-930 JPNXX
Amplifier, 4*60WX
Amplifier, 4*100WXX
Power antennaXXX
Sub-antenna with signal boosterXXXX
Speaker (treble) in dashboardXXXX
Door speakers (mid-range+bass+balance filter)XXXX
Speakers in parcel shelf (bass+treble)XXXX
Dolby unitX
Centre speaker (LHD)X
SC-900/930
Overview
A wide-front radio with large, ergonomically designed controls for simple, traffic-safe operation.
An external amplifier is required; the radio is equipped only with an amplifier for a centre loudspeaker (25 W).
The SC-930 is used in Japan (the radio does not provide RDS; Japanese traffic information is broadcast on two separate AM frequencies). The SC-900 is used in other markets.
Features
The car must be equipped with a centre loudspeaker and a Dolby unit.
The system is active only when the cassette player or CD player (not the radio) is playing.
The Dolby unit divides the normal left and right stereo channels into left, centre and right. The rear speakers also provide ambient surround sound, which simulates the resonance heard in the sound studio. In most modern recordings, the vocalist/soloist is heard in the very front, while the orchestra is heard from all directions, from left and right as well as rear. Dolby ProLogic Surround Sound provides a sound experience which is close to reality (that is, to the recording situation).
Operation of system
Press 'MODE' button to select function. The selection is displayed in the window. Dolby ProLogic 3 CH: Centre speaker active without ambient surround sound Dolby ProLogic 5 CH: Centre speaker active with ambient surround sound.
The volume of the ambient surround sound from the rear speakers can be regulated when the 'BASS' button is pulled out.
The volume of the ambient surround sound from the centre speaker can be regulated when the 'FADER' button is pulled out.
Note! Special attention should be paid to functions shown in bold when replacing the radio.
-Diversity system (two-antenna system)
-RDS with EON
-Radio text, information on programme content Broadcast only by certain stations.
-Traffic information and alarm Priority can be given to traffic information from a specific station. The alarm function can be enabled/disabled.
-Programmable PTY and News button
Preselector buttons 1-6 are programmed for certain programme types (the buttons can be reprogrammed). Different languages (Swedish, French, German, English) can be displayed in the window.
-Electronic volume control
-Automatic volume adjustment for traffic information, news and PTY prioritisation
-Front-rear balance control (fader)
-Left-right balance control
-Separate bass and treble controls
-Automatic loudness control
-Automatic mono/stereo selector
-Connection for centre speaker and Dolby unit
-Telephone mute
-ASC: Automatic volume control according to speed of car The function can be enabled/disabled.
-Adjustment of internal equalizer (with or without loudspeakers in parcel shelf) Normally set in factory or at dealer's premises.
-3 FM bands, 1 AM band (MW + LW)
-Up-down station search and scan function
-Manual station preselection 3-6 FM, 6 AM
-Autostore: Automatic station preselection 10 FM, 10 AM
-AF: Automatic search for alternative frequency The function can be enabled/disabled.
-Adjustment of frequency interval in station search (market setting).
-Prepared for remote control
-Full-logic cassette player with auto reverse, fast forward/fast rewind, search next (NXT) and repeat (RPT), pinch-off, Dolby B, automatic adjustment depending on type of cassette, pause function.
-Built-in 3-disc CD-changer with music search, playing time indication, choice of disc and track, random selection, pause function.
-Functions for control of separate CD changer
-Low-level output for external amplifier
-Factory-programmed anti-theft code
-Diversity system. A double-antenna symbol is shown in the left of the window when the diversity function is active. This symbol disappears in the event of a sub-antenna amplifier fault.
-The message 'Subantenna OK' or 'No subantenna' is displayed if the radio is switched on while preselector button 6 is pressed.
-All characters and symbols are displayed if the radio is switched on while preselector button 3 is pressed.
Volvo S80 2.4 T (235 Pk Rica) Automaat '00
Volvo C70 Cabrio 2.4 T (193 PK) Automaat '99
Volvo C70 Coupe 2.4 T (237 PK Ziptuning) Automaat '02
mga1600
Bedankt voor het uitgebreide antwoord maar wat ik bedoel is zeker niet de antenne versterker. Die zit verder naar achteren. Deze zit in de lengte richting van de auto gemonteerd een paar cm van de rechterzijkant en een cm of 30 van de achterzijde.
Het zal wel iets van een sensor zijn, maar het gekke is dat er geen draden aan zitten. Ander idee?
sbv
Maak anders even een foto en zet die hier neer. Stel anders ook je vraag even op www.volvo850forum.nl
Lambert
ik mis in dit overzicht de subwoofers...(en eventuele versterker)
History:
-Volvo S60 T6 R-design
-Audi A6 sedan Quattro 3.0 V6
-Audi A6 Avant 3.0 V6
-Volvo C70 T5 Summum Polestar
-XC60 T5 Summum Rica
-Audi A5 Sportback ProLine
-V70 D5 Summum Rica
-C70 cabrio 2.4T
-S60 D5 chrono Rica
-S60 2.4T Rica
-V40 Europa
-V40
heerhugo
Lambert schreef:ik mis in dit overzicht de subwoofers...(en eventuele versterker)
Dit plaatje is afkomstig van een Coupé.
Is dat wat jij bedoelt wit ? en zit er op de bovenkant een soort rode laag ?
mga1600
Dit is het ding wat ik bedoel. Enig idee? Ben benieuwdAfbeelding]
sbv
heb je misschien een wat grotere foto een waar wat meer van de omgeving te zien is ?
mga1600
Deze beter? Afbeelding
sbv
Je zou bijna zeggen dat het er later ingezet is. Zeker omdat er geen draden niets heen gaan.
Ik kan het niet thuis brengen
hadico
Er staat me iets bij van een trillingsdemper op die plek, kan er echter bij vnl niets over terugvinden.
mga1600
Bedankt voor jullie bijdragen in de poging dit raadseltje op te lossen.
Ik hou het maar op een trillingsdemper, iets anders kan ik er ook niet van maken. Belangrijk is het niet, maar ik kwam dit onderdeel toevallig tegen toen ik de bekleding daar loshaalde om een antenne versterker te installeren.
groet
appiedriver
is een tracking divice :glasses5:
it,s nice to be important but it,s more important to be nice
RicoK
Big brother is watching you..?? Maar wie is dan de BB?
Volvo S60 2.4 170 PK Edition 02-2001 - Ash Gold Metallic - HU-603 - GROM-audio - 16"; Mimas zomer en 16"; Mimas winter
Turbo Will-I-Am
Good question! :-)
Voorheen: Seat Toledo V5
Voorheen: Volvo C70 T5 Automaat
Nu: S60 D5 Summum, Tunex Stage II
Werk: Volvo V40 D2 (2015)
Turbo Will-I-Am
Good question! :-)
MarioC70
In m,n VW zit ook zo,n soort ding!
Met een boekwerk erbij van een of andere verzekering!
waver
Mogelijk een extra demper omdat het een cabrio is? Of iets voor de stijfheid van het chassis? Zit er maar 1? of ook 1 aan de andere kant?
Waver V70 classic 2.5 20V '97, Vialle LPI, 481.000km V70 D5 2003, 440000km Volvo v50 T5 2004, 361000km
