V8 in de S60?
- ZX10r
Technical specification
Performance
•0-100 km/h 3.9s
•Top speed more than 300km/h
Engine
•Volvo T6 inline six (B6304T4)
•508 hp @ 6500rpm
•575Nm @ 5500rpm
•Max rpm: 7100
•Modified cylinder head and combustion chambers
•Modified inlet manifold and air intake
•Special manufactured conrods
•Garret 3171 turbo
•Ferrita 3.5” stainless steel exhaust system
Drive train
•Reinforced M66C (close ratio) manual 6-speed gear box.
•Haldex E-LSD in rear
•Haldex Gen4 XWD
Chassis
•Tires 265/30R19
•Rims Polestar 9,5X19”
•Chassis lowered 30mm
•Öhlins 3- way shock absorbers
•Reinforced anti-roll bar front and rear
•Track width increased 20 mm front and 40 mm rear
•Polestar-tuned EHPAS steering
•Stabilising X- members, front and rear.
•Modified control-arms with uniballs front and rear.
•Reinforced bushings in sub-frame and control-arms
•Modified engine mounts
Weight
•Total weight 1640kg and optimized weight distribution
Brakes
•Front Polestar-Brembo 6 piston calipers, 380 mm ventilated discs
•Rear Polestar-Volvo calipers, 302 mm ventilated discs
•Brake cooling air intakes from front
Aerodynamics
•Based on tests in Volvo’s wind-tunnel
•Lowered front splitter and larger rear spoiler to reduce high speed lift
•Carbon fiber diffusor
•Body 20 mm widened front and rear
Interior
•Polestar designed seats with increased support. Alcantara on all functional areas steering wheel, gear knob, and seats to ensure maximum grip.
•Centre console lowered for optimised gear-lever ergonomics.
Performance
•0-100 km/h 3.9s
Engine
•508 hp @ 6500rpm
•575Nm @ 5500rpm
•Max rpm: 7100
•Garret 3171 turbo
Drive train
•Haldex Gen4 XWD
Chassis
•Tires 265/30R19
Weight
Brakes
Aerodynamics
Interior
Out XC 70 D5 full option
- guidof
- Discovery
Wow! Toch meer dan ik had verwacht, specs zien er zeer goed uit. Hiermee rijdt je een M3 of RS5 makkelijk eruit. Wagen ziet er ook duidelijk dikker uit dan een R-design.
PS: Misschien beter om de topic titel aanpassen zodat duidelijk is dat dit topic over de S60 polestar gaat.
Ga je over van diesel naar benzine Thijs?
- dutchlimits
Vette bak! Energielabel X?
RIDES:
Dodge Magnum
VW Corrado G60
EXIT:
Audi A4 B6 3.0 V6 30V QUATTRO
Volvo S40 2001
Polo G40 Genesis
Dodge Magnum
VW Corrado G60
EXIT:
Volvo S40 2001
Polo G40 Genesis
- The Volvoboy
Ik denk Z
Koen
- V480-S60
Dit is een echte M3 Killer. Sooooow heeeeee.
Ik ben benieuwd wat dit moet gaan kosten. En of hij werkelijk geleverd gaat worden.
Johann iets voor jou?
- Frederik Welvaert
Ik vrees ervoor. Als je ziet wat er allemaal aan veranderd is denk ik dat de prijs zéér hoog zal oplopen. En ook de prijs voor onderhoud zal niet mis zijn, met zo'n gepushte T6 zal er wel af en toe eens iets kapot gaan vrees ik.
MY05 V50 2.0D
MY05 V50 2.0D
- Volvoman
Bert-Jan Nijhuis
- Laguna-S60
Lijkt mij wel wat zo'n S60
- The Volvoboy
Lijkt het je portemonnee ook wat?
Koen
- V480-S60
Ach zie het item van Autoweek dat Volvoman aanwijst.
Daar staat dat het een one-off is met mogelijk een zeer kleine serie. (Voor veel geld!!!)
Marc Apeldoorn
Duidelijk geen one off. Volvo heeft zelf publiciteit verzorgt, iets wat bij de C30 Polestar nie tis gebeurd. Daarnaast is de S60 Polestar een normale auto zonder vreemd interieur, hetgeen bij de C30 wel het geval was. En er wordt openlijk aangegeven dat bij voldoende belangstelling wordt geproduceerd.
Natuurlijk zal dit geen goedkope auto worden, maar (afh. van batchgrootte) veel duurder dan 80K zal die m.i. niet worden..
S80 V8
XC90 V8
C70 2006
V70 R 2004
V70 T5 2005
S80 D5 GT 2012
V70 T4 LE 2012
XC90 Summum 2006
V70 D5 AWD 2006
S60 D5 2002
850 2.5
XC90 V8
C70 2006
V70 R 2004
V70 T5 2005
S80 D5 GT 2012
V70 T4 LE 2012
XC90 Summum 2006
V70 D5 AWD 2006
S60 D5 2002
850 2.5
- V480-S60
Nou kost een M3 vanaf € 110.000,00
Als deze auto toch in serie gebouwd gaat worden zal een S60 Polestar ook echt wel die richting opgaan. Maak je daar maar geen zorgen over.
En zoals gezegd: Dit is, ondanks de publiciteit door Volvo zelf, wel degelijk een one-off. Met mogelijk een kleine serie.
Maar goed daar ga ik verder niet over redetwisten.
- Johann
Waar dan?Marc Apeldoorn schreef:Volvo heeft zelf publiciteit verzorgt,
Polestar heeft een bericht uit gedaan.
En hij kost €236.000 volgens de berichten.
Geen geld haha!
