Volvo 2014 V8 Supercar engine makes its debut at Sydney 500
In deze rubriek praat je over alles wat met de Volvo Oceanrace, circuitracen en Volvo's te maken heeft.
Bron: www.polestar.com
• Volvo Polestar Racing debuts its first ever V8 Supercar engine
• Race engine developed by Polestar with support from the same Volvo engineering team behind
upcoming Drive-E engines
• Unique engine promises distinctive sound
Volvo has unveiled the engine that will power its two Volvo Polestar Racing S60s in the 2014 V8 Supercars Championship.
Volvo Car Australia Managing Director Matt Braid lifted the covers on the race engine, with Volvo Car Group Motorsport Technical Director Martin Persson and Commercial Director Alexander Murdzevski Schedvin in attendance.
“As the first luxury car manufacturer to field a factory team in the V8 Supercar Championship, we’re delighted to share this milestone moment with you and reveal our race engine for the 2014 V8 Supercar season,” said Matt Braid, Managing Director of Volvo Cars Australia.
“The race team at Polestar have worked hand-in-hand with the engineering team at Volvo Cars to design, build and develop a race engine in Gothenburg, Sweden, to compete in Australia’s premier motor racing category.”
The global resources of the Volvo Car Group and Polestar, Volvo’s performance and motorsport partner since 1996, are being fully utilised to facilitate the development of the Volvo Polestar Racing V8 Supercars in readiness for the 2014 season.
The Volvo B8444S 4.4-litre production V8 has been modified and built specifically for racing in the V8 Supercar Championship by Polestar – supported by the same people in Volvo Car Group who are behind the innovative four-cylinder Drive-E road car engines, which debut in Australia next year.
Thanks to its compact size and narrow 60 degree vee configuration, the B8444S is a truly unique engine on today’s racing grid. With this in mind, motorsport fans can expect to instantly recognise the Volvo Polestar Racing S60s in 2014 thanks to the engine’s distinctive soundtrack.
Christian Dahl, Managing Director of Polestar, said of the race engine: “We have completed a number of high-rev simulations and long-distance runs and we’re very happy with the figures and outcomes we’ve achieved. The next step is to fit the engine to the race car and continue the pre-season development timetable.”
Development of the race engine began back in May 2013. The first block was completed in late October and had its first run on the dyno in mid-November.
“So far, everything is on track with the race engine,” said Volvo Car Group Motorsport Technical Director Martin Persson.
“On paper, this race engine and the new Drive-E engines are quite different. But from an engineering perspective it is a very similar process, and that is to push your imagination and creativity to the limit within a specific set of targets.
“For instance, whether you are aiming for leading efficiency or the most powerful race engine ever to be heard in the Australian V8 Supercars Championship, you will strive to reduce weight, friction, heat and to maximise power.”
Further information about Volvo Polestar Racing will be released in due course.
Technical information
Block: Modified Volvo B8444S, 60 degree aluminium cylinder block
Heads: Modified Volvo B8444S, aluminium
Bore x Stroke: 95.5 x 87.1
Capacity: 4989cc
Compression Ratio: 10:1
Max revs: 7500rpm
Induction: Naturally aspirated, eight throttle bodies
Fuel: E85
Liners: Cast in steel liners
Valve Train: Double overhead camshafts, direct acting tappets, chain drive
Ignition: Volvo B8444S coil on plug
Injection: Port injection, one injector per cylinder, injection pressure: 5.5 bar
V480-S60
Is dit nu een "verbeterd" "Yamaha"blok?
ja volgens mij wel. Maar dan bijna 5 liter inhoud. Hoe zal die klinken?
Volvoman
zien zien zien!!
Bert-Jan Nijhuis
kevinwalter
Inbouwen in de V70 hmmmmm
Volvoman
De auto: S60 V8!!
Bert-Jan Nijhuis
Rob Bakker
Toch bijzonder dat ze het maken.
Volvo geeft aan nergens meer een groter blok dan een 4 cilinder in de toekomst in te gaan bouwen, stoppens ze hier een 'nieuwe' V8 in ;)
Ben inderdaad benieuwd naar de sound van de auto!
the sound!
guidof
/Guido
2020 KIA eNIRO EV
2011 Volvo V70 II DRIVe Momentum
1999 Volvo S40 1.8 Europa
AfbeeldingAfbeelding
rendier1
Deden het gelijk goed in de race!!!
Als je van close-racing houdt kijk dit....
gsx750r
Geweldig resultaat en ook geweldig om te zien. Ik ben sowieso al helemaal gek van standaard auto's die zo heerlijk breed zijn uitgebouwd.
Doet me weer denken aan de tijd dat ik nagenoeg alle toerwagens races in Zandvoort bezocht. Dikke Capri's, BMW's, Escorts enz. Zgn. deurklinkgevechten, geweldig!
Toerwagens races vind ik over het algemeen toch veel leuker om te zien dan de Formule I met dat gelul over 'pitstopstrategie'! Wat nou pitstopatrategie of verplichte bandenwissel.......racen doe je op de baan en degene die het eerst aankomt is de winnaar. Best heel simpel: "Kijk knul, hier staat je auto, de tank is vol, de banden zijn nieuw en op spanning en gaan met die banaan! Zorg dat je als eerste aankomt en je redt je verder maar. Succes en tot over 70 ronden" Voor iedereen te begrijpen en ......... het blijft ook lekker overzichtelijk! Vaak is het ook nog eens gewoon een optocht met grote tussenruimtes.
Echte gevechten voor een plaats zie je steeds minder.
Maar goed, dat zal ook wel weer vooruitgang zijn. Het wachten is nog slechts op autonome raceauto's die vanuit de pit worden bijgeregeld. Misschien iets voor Volvo om dat te ontwikkelen .......... :devil: Op naar de risicoloze racerij.
Rob
Volvoman
Gewonnen!
Bert-Jan Nijhuis
guidof
Heel fraai!
Afgelopen vrijdagavond de eerste ronde vanuit Adelaide op tv zitten kijken (via Motors TV).
Erg gaaf en erg close racing.
Is dit in Nederland ook te volgen?
(foto's via instagam)
/Guido
2020 KIA eNIRO EV
gsx750r
guidof schreef:Is dit in Nederland ook te volgen?
Ja, ik kan het hier (Portugal) ook volgen. Als je Motors TV in je CanalDigitaal pakket hebt zitten is ontvangst geen probleem.
Rob
Jeroen
Volgen mij heb ik Motors TV, zal leuker en spannender zijn als die brommer optocht wat Formule 1 heet in 2014.
Terug naar “Volvo Racing Nieuws”
