De nieuwe S60
Gesloten
rsnhakan
945i schreef:rsnhakan, volgens mij mag jij nog niet links zitten..... :wink:
Maar tegen die tijd dat we een V60 hebben, wel :)
rsnhakan
Hebben jullie deze video al gezien? (met spraak)
http://www.autoweek.nl/video/1538/Volvo ... -op-de-weg
BRON: Autoweek
V50R-enik
Wel op de oprit :wink:
2009 V50 2.0D Edition II | R-design & RTI | Edition Plus Pakket | Sportonderstel | Chip
rsnhakan schreef:Hebben jullie deze video al gezien? (met spraak)
BRON: Autoweek
Ja, kijk eens een stuk of 10 berichten hoger :twisted:
Sorcerer
Argh argh argh! Is het dan toch een S60R? Er zijn al 2 aanwijzingen voor dat het een S60R is:
1) het interieur is oranje
2) geruchten intern bij Volvo
3) vertaling van het artikel (slechte vertaling via Google Translate, lachen toegestaan):
New Volvo S60 - first test skiing
Hans Hedberg was one of very few selected people who had to travel with the final test of the new Volvo S60 and the new Collision Warning with Full Auto Brake which can detect pedestrians and slow down fully on a collision would be close.
The art world has previously had a taste of the new Volvo S60 then we had to drive the Volvo S60 Concept on a avlyst orbit. Now the technology world in the form of Hans Hedberg also had a taste of a pre-series of production-ready version. He was with Volvo on a field test in which the final test of the new Volvo S60 and Collision Warning with Auto Brake Full (abbreviated remain Auto Brake in the article) took place. Auto Brake is the system that will complement the XC60 was launched with City Safety, which detects the vehicle in front and thus can help the driver avoid or reduce the effects of collisions at low speeds, for example in town or in bilkön. Auto Brake differ on this point that it is aware of the people instead of vehicles using a radar and a camera. The radar works at distances up to 150 meters while the camera is working within a closer range - 50 meters. The system detects and verifies that it is a person such as is going over the crossing point, while the driver may not notice this in front of him. Then step into the system and can slow down with full force to prevent contact with the person who passes the crossing point. There is a charge a mother with her baby carriage, it is the mother that the system identifies, not the pram.
Another better example is a ball that rolls out on the road or street with a small child running after. The driver did not have time to react, but it makes the system. In speeds up to 25 km / h is the system entirely able to avoid collisions, at speeds over it, it is rather that the system slowing down as much as possible. Volvo says the system in most cases can reduce the collision force by 75 percent.
For the system to register the "object" in front of the car as a man, this is at least 80 centimeters long. This corresponds to children aged around 15 months, about when children start to learn to walk.
But enough about Auto Brake now, we beat Hans Hedberg rapid signal after a full day with the new S60. What is his experience of the car that many are waiting for?
Hey Hans, you have therefore been in Copenhagen and got a little closer look at the new S60. What is it?
- Unfortunately, this car is heavily disguised, but call it the closer you will see that several features and lines hanging from the popular concept that was shown last spring.
But you've got to go with it?
- Yes, we have been out and tested Auto Brake and from the back seat I saw a lot of interior although it also was partially masked. From what I saw, I saw a lot of XC60-influences. Same features, same feeling and a new steering wheel - a three-spoke, which is very similar to the one shown in S60 Concept.
And back then?
- Good entry-level and spacious, especially in width. Better than new Saab 9-5 despite Volvo lirar in the class below. Head height seems okay, thanks to low slung seat cushion. Better than the old S60, but it also provides a higher lateral line seen from the inside.
How did you feel it when it rolled?
- Since this is a pre-series may be prepared on the creaking and gnekande, but not here. Solid and well built it seemed. It was a great pressure in the engine, it was in a car. Automatic transmission and dual exhaust rear. If you have pictures can of course check out what kind of engine under the hood.
According to the registration certificate, this is a strong 272 horsepower engine. A figure old S80 T6 had at one time. Feels like the figure is not really true. Anyway, it was much force in it. We can well conclude?
- Yes, really. Must run now to catch the flight to Munich. We heard.
But you! As sales continue running?
- In summer.
Psst ... the new Volvo S60 in almost unmasked condition, see the link below. Do not miss our test drive of the S60 Concept on TV TV, even via the link below.
S60 2.4 140pk (2001) - 2007 - 2009
S60R MY05 300pk (2004) - 2009 - heden
Johann
Is een 285PK T6 AWD en naar het zich er laat uitzien krijgt deze motor binnenkort een powerboost i.v.m. overstap naar directe inspuiting. Vermogen zal waarschijnlijk net boven de 300 PK komen te liggen. Als het dan een handbak is dan heb je in principe een nieuwe R ja.
Sorcerer
Waar heb je dit gelezen? Dit was namelijk een 272 pk motor, geen 285 pk... en dat was juist het raadselachtige. Ook suggereert het Zweedse artikel dat de typeregistratie niet klopt en de auto meer vermogen zou hebben dan de opgegeven 272 pk (= 200 kW).
Dus toch spannend...
Johann
KW's van de mule auto's kloppen vaker niet. XC60 stond ook als zijnde 200KW op papier en die heeft ook gewoon de nieuwe T6 285 PK.
@Sorcerer
Laten we nou niet alles over de nieuwe S60 dubbel gaan plaatsen. Dan wordt het nogal onoverzichtelijk.
Zie http://www.volvo-forum.nl/viewtopic.php?p=589951#589951
volvo
Nou zie ik in dit filmpje toch wel heel veel van de S60. Maar ik kan niet geloven dat het dak van glas blijft in de productie-uitvoering
http://www.teknikensvarld.se/tvtv/09052 ... /index.xml
jippen
Er komt een t6 met 305 pk.
nieuwe 2.0d diesel ( die van ford)
interieur zelfde als xc60 maar het bovenste display verdwijnt en ander stuur.
Er komt standard een 5 inch scherm in (en als je rti neemt 7").
Testen zijn bezig met city safety tot 50 km maar niet zeker of deze het haalt als de s60 in produktie gaat.
Sorcerer
jippen (uit Gent neem ik aan ;)): ook al een idee hoe het verbruik van de T6 met 305 pk zal zijn? Hopelijk een heel stuk minder dan dat van de huidige T6?
Ik neem verder ook aan dat er weer een D5 komt, en heel heel heel misschien wel een krachtigere diesel, zoals BMW en Audi die ook leveren in de vorm van een 3.0 V6 TDi.
En weet je al iets over een eventuele nieuwe S60R? Want dat prototype had een verdacht oranje leerkleur!
Johan
Geachte heer/mevrouw,
Detroit, Genève en Frankfurt en in onze eigen RAI tijdens de Woonbeurs was men laaiend enthousiast over de Volvo S60 concept car. Toonaangevend in het ontwerp was Volvo’s nieuwe Design DNA. Strakke, dynamische lijnen; zelfs stilstaand suggereert de concept car beweging. Maar nu is het genoeg, de S60 concept car is voortaan alleen nog te bewonderen in het Volvomuseum. Het is tijd voor de productieversie.
Officiële foto’s en beeldmateriaal krijgt u voorlopig nog niet te zien. Natuurlijk willen we u niet helemaal in het ongewisse laten. Een bijzondere auto verdient een bijzondere presentatie, een bijzonder verhaal. We vroegen de Turkse kunstenaar Esref Armagan een schilderij van de nieuwe Volvo S60 te maken.
Bijzonder? Jazeker. Esref is namelijk blind, al vanaf zijn geboorte. Hij heeft nog nooit een auto gezien. En juist daarom vroegen we hem. Hij leerde zichzelf schilderen, het zijn unieke platen. Volvo’s eigen kunstenaar Peter Horbury ontving Esref in de Designkelder in Göteborg.
Van het maken van dit schilderij hebben we een documentaire gemaakt en een voorproefje daarvan kunt u zien op Volvo’s Facebook-pagina. De volledige documentaire en het schilderij zullen binnen enkele dagen worden onthuld.
In de tussentijd kunt u speciale verzoeken indienen bij Esref. Bent u benieuwd naar een speciaal detail van de nieuwe Volvo S60? Vertel het ons en misschien maakt Esref er een tekening van.
Ik hoop dat deze preview u net zo boeit als mij.
Bekijk de "Blind Preview" op www.facebook.com/Volvo
Met vriendelijke groet,
Director Marketing
Stationsweg 2, NL-4153 RD Beesd
P.O. Box 16, NL-4153 ZG Beesd
mods-edit adresgegevens verwijderd.
BMW 520D steptronic automaat, high executive, HiFi professional audio, sportstoelen etc. etc.
S60 2.5T Drivers Edition, Top line, Black Sapphire, Sportleder Light Sand, Premium Sound - IMIV, Geïntegr. Telefoon, Orpheus 17, MY2009.
S60 D5 Edition, black sapphire, nordborg light sand, electra 16, high performance audio MY2005.
jippen
De zweden waren schaars met info , ze wilde of konden niet meer informatie meegeven over motorisaties.(ik zit waarschijnkijk te laag op de ladder om alle info zo vroeg te mogen ontvangen ;-) ) We hebben wel al de afgewerkte versie gezien.Onze president was laaiend enthousiast over de rij eigenschappen van de nieuwe S60 en V60.
Sorcerer
Naja, nog een paar maandjes wachten :)
En dan misschien inderdaad gaan kijken in Genève en er gelijk een vakantie in Zwitserland aan vastplakken :)
ALF
volvo schreef:Nou zie ik in dit filmpje toch wel heel veel van de S60. Maar ik kan niet geloven dat het dak van glas blijft in de productie-uitvoering
Is nog steeds concept versie waarin ze rijden dus...
V70 D5 163PK 2002 AUT5, Moondust, HU-803 Dolby Pro Logic
Volvoman
Dat preview filmpje op Facebook is wel aardig, er zit in ieder geval 1 mooie welving aan de auto!
Bert-Jan Nijhuis
Johan
En dit is hem dan .....
Carel
Volvo S60 wordt gepresenteerd in Geneve.
http://www.telegraaf.nl/autotelegraaf/5 ... nve__.html
Volvo C70 Tourer 2.4i geartronic Magic blue pearl (juni 2009)
Volvo C70 2.4 momentum geartronic Zilvergrijs (januari 2007)
zwolly
Maurice Pierik schreef:Iedereen die beweert dat de nieuwe S60 op een Ford lijkt is ernstig in de war.
ford taurus??
zwolly
S40 1.8 11-1996 donkerrood metallic handgeschakeld (verkocht)
S40 1.8 09-2001 pure silver sports automaat (verkocht)
S60-D5 edition -11-2003- black stone-handgeschakeld. (verkocht)
Mercedes S-klasse coupe V8 , nieuwstaat,automaat en alle opties, lpg.
Gesloten
