Nee, heeft niets met city safety te maken. Je kan instellen dat je een bepaalde snelheid, bijv. 120 km/h, niet overschrijdt.Fulaks schreef:Bedoelen ze met "A driver-set speed limitation device " het City Safety-gebeuren ? En wat is daar "driver-set" aan ? Dacht niet dat je dat kon uitschakelen ?
Hier nog een uitleg:
Maintains speed
The new Volvo V60 is also fitted with Speed Limiter, a function that helps prevent the driver from exceeding a given speed, for instance the legal speed limit.
High speed is a contributory cause behind a significant part of all fatal road accidents. Swedish Road Administration research shows that between 100 and 150 lives would be able to be saved on Swedish roads every year if drivers kept to the speed limits.
"With the Speed Limiter activated, the driver does not need to watch the speedometer but can instead concentrate on other vehicles and road users. The car itself ensures that the set maximum speed is not exceeded," says Thomas Broberg.
