Resetting the service reminder indicator (SRI)
Hint:
The indicator can also be reset using VIDA vehicle communication.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
Ignition position I
Press and hold in the reset button for the trip odometer
Ignition position II
The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
Ignition position I
Ignition position II.
Note! Turn the key to position II within 2 seconds.
Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
zelf onderhoud doen
- V70/2.4D/2003
Mooi.
En dit gaat over.......?
En dit is bedoeld voor.....?
Voor de verwijdering van de servicemelding staat hier trouwens al meer op het forum, maar dan gewoon in plat Nederlands.
V70 D3 MY12, Caspian Blue
Gast
Ik heb het even voor je vertaald:
Servicelampje resetten, modeljaren -2001
Het servicelampje laat de bestuurder weten dat het tijd is voor een onderhoudsbeurt voor de auto.
Het lampje blijft gedurende 120 seconden branden wanneer het contact wordt ingeschakeld.
Opmerking! Indien het lampje knippert, kan dit zijn omdat één van de onderhoudsparameters niet geprogrammeerd is.
Ga als volgt te werk om het servicelampje te resetten:
-Contactstand I
-Druk de resetknop voor de dagteller in en houdt deze ingedrukt
-Contactstand II
-Het servicelampje begint met knipperen wanneer de reset-knop voor de dagteller 10 seconden is ingedrukt
-Laat de reset-knop voor de dagteller binnen 5 seconden los.
Het instrument geeft een akoestisch signaal wanneer het resetten gelukt is.
Opmerking! Indien de reset-knop van de dagteller niet binnen 5 seconden wordt losgelaten, is het controlelampje niet gereset.
Het controlelampje houdt dan wel op met knipperen.
Servicelampje resetten, modeljaren 2002-
Het tekstbericht wordt 120 seconden getoond elke keer dat het contact wordt ingeschakeld.
-Contactstand I
-Contactstand II.
Opmerking! Draai de sleutel in stand II binnen 2 seconden.
-Houd de resetknop voor de dagteller ingedrukt tot de oorspronkelijke waarde weer is ingesteld.
Opmerking! Bij alle voertuigen vanaf het 2003 modeljaar gaat er een algemene gele lamp branden wanneer de resetknop moet worden losgelaten.
-Laat de reset-knop voor de dagteller binnen 4 seconden los. Het instrument geeft een akoestisch signaal wanneer het resetten gelukt is
-Als de dagteller al opnieuw is ingesteld, moet de reset-knop minimaal 10 seconden en maximaal 14 seconden ingedrukt worden gehouden.
Opmerking! Indien de reset-knop van de dagteller niet binnen 4 seconden wordt losgelaten, is het servicelampje niet gereset.
-Contactstand I
-Contactstand II
-Contactstand I
-Contactstand II.
- V70/2.4D/2003
AlexV70, ook niks te doen op zaterdagavond?
Enniehoe: as i said, staat al (meerdere keren) vermeld op het forum.
- ovlov058
En nu staat het terug bovenaan
Misschien een stikkie van maken, er zijn nog onderwerpen die bovenaan mogen blijven staan, zeker als het forum blijft groeien.
S80 25D 1999 Chrysler Stratus Cabrio 2.0 16v lpg 1999
855 2.0 20V 93
855 2.0 20V 93
- euerw
lijkt wel zo`n starter die iets neer zet en nooit meer iets laat horen.
Chalith wat is nou de bedoeling?
S60 MY'02 2.4 bifeul automaat
