Ik vond het volgende :
http://volvoforums.com/forum/volvo-v70- ... post144605
en dat is echt 100% dezelfde set van symptomen als bij mijn V70.
Vond ook nog een recall :
2004 Volvo V70 Recall ID from NHTSA: 07V226000
Auto Recall Date: 06/05/2007
Vehicle Component: ENGINE AND ENGINE COOLING
Estimated Vehicles Affected: 38700
2004 VOLVO V70 Defect Summary:
ON CERTAIN PASSENGER VEHICLES, THE FUEL PRESSURE SENSOR LOCATED ON THE LEFT END OF THE FUEL RAIL MAY, AT TIMES, TRANSMIT INCORRECT SIGNAL REGARDING THE FUEL PRESSURE TO THE ENGINE CONTROL MODULE. IF THE SIGNAL IS OUTSIDE OF THE PRE-PROGRAMMED ALLOWABLE LIMITS, A DIAGNOSTIC TROUBLE CODE MAY BE SET AND THE CHECK ENGINE LIGHT WILL COME ON. THE SOLDERED JOINTS ON THE CIRCUIT BOARD OF THE FUEL PRESSURE SENSOR MAY CRACK DUE TO TEMPERATURE CHANGES AND EXCESSIVE VIBRATIONS.
Defect Consequence:
MISFIRE MAY OCCUR DURING DRIVING THAT, IN TURN, WILL REDUCE THE ENGINE TORQUE AND IN THE WORST CASE SCENARIO, THE ENGINE MAY STALL WITHOUT WARNING. IN CERTAIN TRAFFIC SITUATIONS THIS COULD CAUSE AN UNSAFE SITUATION AND POSSIBLY A CRASH.
Remedy:
DEALERS WILL REPLACE THE FUEL PRESSURE SENSOR FREE OF CHARGE. THE RECALL BEGAN ON JUNE 29, 2007. OWNERS MAY CONTACT VOLVO AT 1-800-458-1552.
Notes: VOLVO CARS OF N.A. LLC., R181
