Wat apparaatjes die aan te sluiten zijn op de cd wisselaar aansluiting van Volvo radios. En niet al te duur.
"The PA11-VOL is a smart iPod interface that lets you Play, Control and Charge the iPod or iPod Mini through a compatible VOLVO factory Stereo.
Compatible only with listed 2001-05 Volvo with HU- Series factory radios and CD Changer controls."
"Smart iPod™ interfaces provides full function of the iPod™ utilizing the CD Changer functions of the OEM radio and steering wheel.
The PA10-HON is also compatible with select 1991-00 Volvo factory radio model SC-710, SC-810, SC-811, SC-813, SC-816, SC-901 etc [not compatible with any HU-*** headunit.]. Radios must have a "CD" [8-Pin Mini-DIN connector on the back.]"
Heeft wel deze kabel nodig geloof ik.
"The VOL/AUX DMX V.1 by Blitzsafe is an interface device that converts the CD Changer port on the back of the radio into an auxiliary input. Once connected you can input the audio from a single source such as [iPod, MP3, DVD, Satellite Radio ( Delphi Roady, Commander, Starbase etc.), X-BOX, Playstation, VHS player, and others] directly to select Volvo factory audio systems without using an FM Modulator which is the current method of introducing audio into these systems.
The VOL/AUX DMX V.1 is compatible with all Volvo's listed in the "Order Options" pull-down above having a Volvo factory radio model SC-710, SC-810, SC-811, SC-813, SC-816, SC-901 etc [not compatible with any HU-*** headunit.]"
"The VOL/M-LINK1V.1 interface is for those of you wanting a clean audio connection, the ability to charge and Navigate all menus and controls using the iPod™ buttons. The VOL/M-LINK1V.1 connects to the CD Changer port on select Volvo vehicles and allows the audio from your iPod™ to be heard on the factory speakers, you control the iPod using the iPod buttons and while connected the iPod™ will also charge.
Compatible with all Volvo radios model SC-710, SC-810, SC-811, SC-813, SC-816, etc [not compatible with any HU-*** headunit.]"
