Reset Service indicator
Wie weet hoe ik de service indicator kan resetten. Het onderhoud is intussen door mijzelf gedaan en ik wil graag de melding met de bekende moersleutel weg hebben.
V70 D M11 Magic Blue TUNEX 230PK
V70 D M09 Electric Silver FASTTECH 220pk
Ik heb het op een USA site gevonden. Ik heb het inmiddels uitgeprobeerd en het werkt!
Reset Service Reminder Indicator on 1998-2009 Volvos
Some 1998 and older models require a OBDII service light reset tool. You can probably have it reset for a marginal cost by a local Volvo dealership or Volvo specialty shop that has one of these tools.
1998 Volvo S80 Models
* Turn ignition switch to position I
* Press and hold the odometer reset button
* Turn ignition switch to position II
* After Service light flashes, release odometer reset button
* Turn ignition off
* Turn ignition back on to confirm reset
1999-2000 Volvo S70 / V70 / C70 Models
* Insert key in to ignition but don't turn it yet
* Press and Hold the odometer trip counter reset button
* Turn ignition switch to "run" position (Position II)
* Turn ignition off
1999-2000 Volvo S80 Models
* Insert key and turn ignition switch to position I
* Press and hold odometer trip counter reset button
* Continue holding odometer trip counter reset button for about 10 seconds
* Should hear "beep-beep" to confirm command accepted
2001 Volvo S80 / V70 / S60 Models (May apply to S40/V40 also)
* The service reminder indicator lamp illuminates for 120 seconds when the ignition is first switched on.
* Insert key and turn Ignition Switch to position I
* Press and hold in the reset button for the trip odometer
* Turn the Ignition switch to position II (within 5 seconds)
* The service reminder indicator starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
* Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
* If the trip meter reset button is not released within 5 seconds the indicator is not reset, but the indicator will stop flashing.
2002-2007 All Volvo Models
* Turn the Ignition switch to position II (within 2 seconds)
* Hold the reset button for the trip meter pressed in until the original trip counter value blinks and is redisplayed
(For all vehicles 2003- a general yellow lamp will light when the reset button must be released.)
* Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
* If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
* If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
2008-2009 Volvos with starter push button on dashboard
* The trip odometer must have at least 0.1 mile on it or the light will not reset.
* Get in vehicle and do not push down on the brake pedal
* Put the key in the slot and push the starter button once
* Press and hold down the odometer reset button
* While doing this, push the starter button again and hold for 2 seconds
* Keep the odometer reset button held in and watch the instrument cluster for the general warning indicator (I) to illuminate. When this happens, release the button.
* Turn the vehicle off then back on and verify the message is now out.
* Turn ignition off
* Turn ignition off
- Dieselaar
- deur open laten
- druk resetknop in en houdt deze ingedrukt
- zet onmiddelijk contact aan in stand II
- houdt resetknop ingedrukt tot service bericht verdwijnt
- laat resetknop binnen 4 seconden los
- er klinkt een signaal als het resetten is gelukt
V70 D5 geartronic summum 2006
Saab 9-3 1.9TiD
- Dieselaar
sleutel in slot is contact aan maar jij hebt dus een ander model, dan even kijken bij de vorige post :
_________________
_________________
Saab 9-3 1.9TiD
- xc-men
Hebben jullie ook iets voor het:
Model "Vrouw" bouwjaar 1961, ze will maar niet aan een nieuwe Volvo.
XC-MEN: XC70-D5-GT-MY08-Summun, Rica PPC Tuning +/-220PK
XC-WIFE: SEAT LEON 2.0 TDI 170PK MY12 Full options
