What car? over de V70 met nieuwe D4 2.0 vier cylinder
Boreas
Onderstaand de mening van What car? over de V70 met de nieuwe D4 2.0 vier cylinder. De Golf Estate blijkt zelfs een alternatief voor de V70 beschouwd te worden! Wees gewaarschuwd: some strong language voor de Volvoliefhebber!
Jan 31, 2014
This is the first major update to the Volvo V70 since its launch almost seven years ago. The big estate also becomes one the first Volvos to get the company’s efficient new 178bhp D4 diesel engine.
While the V70 can’t match the 99g/km CO2 output of the S60 saloon, it still emits less than most other premium estate rivals, including the BMW 5 Series and Mercedes E-Class – which means it's cheaper to run as a company car.
What’s the 2014 Volvo V70 D4 like to drive?
We were impressed by the refinement of Volvo's new D4 engine when we tried it in the S60 saloon, but sadly it isn't as hushed in the V70. Granted, it makes far less of a racket than Volvo's older five-cylinder engines, but it still sounds grumbly around town and boomy when revved.
The eight-speed automatic Geartronic gearbox doesn’t work as well as it does in the S60, either. It’s indecisive at low speeds, and hangs on to gears for too long when you’re accelerating, which only adds to the engine drone. It’s nowhere near as slick as an automatic 'box in the BMW 5 Series Touring – or even the one in the VW Passat Estate.
The engine’s power is more impressive; there's plenty of pull across the range range, and acceleration isn't quite as smooth as it is in some rivals, it's easy enough to build speed progressively.
The V70 gets Volvo’s Four-C active chassis system that lets you choose three suspension modes: Comfort, Sport and Advanced. In reality, these settings feel little different from one another, and none help to counter the vague steering that doesn’t weight up consistently through corners.
The ride is also pattery over poorly surfaced roads, and around town the V70 shudders over larger ruts and bumps. The BMW 5 Series and Mercedes E-Class are both more comfortable options.
However, road noise is well contained at speed, so the V70 makes a decent long-distance tourer.
What’s the 2014 Volvo V70 D4 like inside?
As you’d expect from a large estate car, there's plenty inside. Four adults have plenty of head- and legroom, so the V70 is well-suited to family outings.
You also get a well-shaped boot, although it is on the shallow side, so isn't ultimately quite as big as it looks. Its 575-litre space narrowly beats the Audi A6 Avant and BMW 5 Series Touring, but the vast Mercedes E-Class Estate has another 120 litres of space.
That said, all the V70’s cabin materials feel classy and durable. The dashboard smart enough, though not quite as flashy as a BMW 5 Series', and some of the controls on the centre console are rather confusing.
Standard equipment is generous across the range. Entry-level Business Edition cars get 16-inch alloys, climate control, Bluetooth, a DAB radio, cruise control, and LED daytime running lights.
SE Nav adds 17-inch wheels, an auto-dimming rear-view mirror, leather-faced seats, automatic lights and wipers, plus a powered tailgate. Range-topping SE Lux models get an electric driver’s seat with memory function, as well as xenon headlights.
Should I buy one?
If you’re looking for a practical load-lugger for your company car, the new V70 D4 should be on your shortlist. Its low CO2 emissions and tempting price put monthly company car tax on par with an equivalent VW Passat Estate, and considerably lower than rivals from BMW and Mercedes.
However, if you can find the extra, the BMW 5 Series Touring is a much better car – and worth the extra. Private buers have even more reason to choose the BMW, because its higher price is largely offset by much strong reslae values.
The VW Golf Estate is also worth considering. It might not seem like a natural rivals to the V70, but it's better to drive and alsmost as practical. It's also significantly cheaper – both as a private buy or a company car.
- See more at: http://www.whatcar.com/car-news/volvo/v ... wi2jd.dpuf
Meus automobilis non volvit, sed currit.
Boreas
Laat nou vandaag Volvo mij een folder over de vernieuwde V70 /CX70 Nordic met die nieuwe mooie motoren toezenden! Dat kan geen toeval zijn! Het blijft een fraai klassiek koetswerk van de V70/XC70 ................ Ik begrijp nog steeds waarom ik deze auto gekocht heb, zeker met een lekkere handgeschakelde D5.
BlackSapphire
verwijderd
Laatst gewijzigd door BlackSapphire op 01.01.1970 - 01:00, 2 keer totaal gewijzigd.
Roel
