Spark Plugs for S40 1.8 122hp 2003 yr with LPG - Vialle LPI
hotsteel
Hi Volvo fans,
Please excuse me for using English, it is because I don't speak Dutch :)
I need some support for S40 1.8 122hp from year 2003.
The car is with a LPG system - Vialle LPI with liquid Injection and I mostly drive it on LPG.
I decided to seek your support as this model of Volvo and Vialle are Dutch products and I hope
here are many people that have dealt issues with them.
What are the suggested type of Spark Plugs by Volvo for this car?
Is there a type of plugs that you prefer for this engine driven with such LPG?
I drive the car around 40000 km per year mostly on LPG and for me the most important issue
is the fuel consumption and the engine performance.
Thank you
Laatst gewijzigd door hotsteel op 01.01.1970 - 01:00, 2 keer totaal gewijzigd.
With the 850/S/V70 models with 5 cilinder engines on LPG the experience is that the original Volvo spark plugs give the best results. All alternatives gave less souplesse and more hick ups. And as your 4 cilinder engine is from the same family as the 5 cilinder, I would recommend you to use the original Volvo spark plugs
hotsteel
Walter schreef: With the 850/S/V70 models with 5 cilinder engines on LPG the experience is that the original Volvo spark plugs give the best results. All alternatives gave less souplesse and more hick ups. And as your 4 cilinder engine is from the same family as the 5 cilinder, I would recommend you to use the original Volvo spark plugs
Thanks for your recommendation. Is it valid also for lpg engines that are with liquid propane injection (like Vialle LPI)?
Mods break
Omdat dit een Nederlandstalig Volvo-forum is, wordt gebruik van de Nederlandse taal op prijs gesteld.
Voor andere talen zijn er voldoende alternatieven op het www.
Yep, especially when used with LPG of LPI! And as Ben asked, as this is a Dutch forum we must continu in Dutch. Google translate can be your friend
Laatst gewijzigd door Walter op 01.01.1970 - 01:00, 1 keer totaal gewijzigd.
hotsteel
Hartelijk bedankt!
Je hebt me veel geholpen!
hotsteel
Ben schreef: Mods break
OK
Ik zal proberen Google Translate te gebruiken. Hoewel het verre van perfect is :)
hotsteel schreef: Hartelijk bedankt!
graag gedaan :)
