Uhm, kun je iets precieser zijn welk gedeelte van mijn verhaal 'exact' is? Als ik een 4e gen iPod alleen kan bedienen met playlists bel ik morgen mijn (al weken) in bestelling staande adapter af...Paul schreef:jep, exact behalve met de video maar dan moet je aparte handelingen doen...
welke iPod aanschaffen
We have two ipod threads here and two in the R forum - be nice to consolidate!
Here is what my testing shows on a 2004 S60R, HU 803 w/NAvi, iPod formatted for the Macintosh with the Volvo adapter:
1. My 4th gen 20 GB (last before photo) with software ver 3.1 worked fine, given the crippled Volvo interface...
2. My new 5th Gen (Video) version 1.0 60Gb DOES WORK as follows:
No Volvo for Life Screen on iPod, it says "okay to disconnect" - In this mode it works just like the earlier versions with the Volvo interface - NO problems.
To make it work as an iPod and use the Apple Interface:
1. iPod must NOT be fully charged
2. Connect to Volvo interface with everything off and make sure the HU is NOT on the changer selection...
3. Turn on key, iPod will say "charging" - hit menu button twice - it goes back through the okay to disconnect screen to the Apple interface.
4. Select changer on the HU
5. Select songs or videos from the iPod!
6. Use volume and track controls on the steering wheel or HU
7. IF, IF you use the DISC knob on the HU to go to a play list, the iPod WILL REVERT to Volvo control only mode...
8. When in the "Apple Menu mode" and the car is turned off, when the car is turned back on, the iPod stays in Apple, not Volvo mode.
Is the connection work around a pain? Yes, BUT I finally have full Apple interface control, so who cares!
I will continue to test and try to refine the connection steps. I also will call Phat Noise and see if they want to talk about this....
Feel free to email me with questions...
-FireR
I am thrilled I can use the iPod from its interface. Are the
-FireR
Ja leuk, maarrrrrr.... Mijn vraag is dus: wat wordt onder "working fine" gerangschikt?
Heeft de interface de mogelijkheid om met de hand op de iPod een artiest/album/track kiezen en die dan af te laten spelen, of kun je alleen door de playlists navigeren met de HU?
Ik heb de handleiding van de adapter (nog) niet gezien, dus ik weet niet welke functionaliteit Volvo met de adapter levert?
Nouja, ik zal wel zien, als het bras is verkoop ik het setje wel weer
ja dan dus als je dus een niet opgelaade ipod hebt dan kan je dus soms per ongeluk hem wel bedienen, en dat staat hier soort van uitgelegd.
maar verder zie je alleen Volvo for Life in je scherm
Okee, een laatste poging om het duidelijk te krijgen:
Als ik een op dat moment spelende (niet-video) iPod aan de dock-kabel van de Volvo adapter knoop, stopt het afspelen dan of neemt de HU het dan over?
Ok, dan maar een reactie op m'n eigen postarnoudh schreef:Okee, een laatste poging om het duidelijk te krijgen:
En nee, dat kun je dus niet doen. Als je een spelende iPod aan de Volvo-iPod-adapter koppeld wordt het op dat moment spelende track gestopt en schakeld ie automatisch naar CD01 TRK 01... Helaas...
Dus bij deze: ik heb een 5 minuten gebruikte, nooit ingebouwde originele Volvo iPod adapter te koop, inclusief alle aansluitkabels om hem in een V40 in te bouwen. Inclusief een dikke 4 meter lange Melbus kabel, ook geschikt voor een V70 bijvoorbeeld. Voor een andere auto dan een S/V40 heb je nog wel de stroomvoorzieningskabel nodig. Voor 90 euro (in de BTW natuurlijk) is ie van een nieuwe eigenaar....
- interface
@ arnoudh,
nou, lekker dan. Ik heb ook zo'n kabel besteld, maar ga er ook maar van afzien.
Alleen…… welke oplossing blijft nu over om een iPod lekker werkend te krijgen -in mijn geval met een HU-803.
maarten
maarten
Volgens mij moet de USA-SPEC adapter het toch ook gewoon doen met de HU-803?
Wel een beetje jammer dat de Volvo adapter je iPod veranderd in een 10-CD wisselaar (wel met heel veel nummers op een CD als je dat wilt), maar het werkt wel natuurlijk.. En makkelijker aan te komen dan een adapter uit de VS zien te importeren...
- interface
Zal het eens goed uitzoeken. Maare, wat verschilt (behalve de prijs) de ene iPod adapter nou werkelijk van de ander. En dan heb ik het over de originele Volvo iPod adapter en de USA SPEC - PA11VOL.
Ben benieuwd naar je/jullie bevindingen en welke je me zou aanbevelen.
De verschillen zijn:
- de Volvo adapter gedraagt zich 100% als een 9-CD wisselaar (CD10 zijn ALLE nummers op je iPod). Je moet op je iPod (via iTunes) playlists aanmaken, en deze playlistst zijn dan de verschillende 'CD's. Die kun je dan met je radio bedienen.
- de USA-SPEC gedraagt zich als een 6-CD wisselaar. Je kunt dus minder playlists maken (5 + ook de 'ALLE' nummers). Daarentegen kun je de USA-SPEC op een andere manier gebruiken: er zit een schakelaar op waarmee je de iPod kunt bedienen in manual mode, waarmee je terwijl de iPod aangekoppeld zit aan de adapter met het clickwheel kunt bedienen (maar dan niet via de radio). Ook kun je de iPod loskoppelen, een nummer/album/playlist selecteren op de iPod, afspelen starten en de iPod weer vastkoppelen. Nu zal de iPod gewoon doorspelen (met de Volvo adapter stopt dan de weergave, voor mij DE reden om niet de Volvo adapter te kiezen).
Verder heeft de USA-SPEC ook nog een AUX ingang, waarmee je ook andere apparaten dan een iPod met twee tulp-stekkers aan je radio kunt knopen.
Als je het wilt kun je voor de Volvo adapter gewoon naar de dealer gaan, een zak geld meenemen en de hele boel netjes laten wegwerken. De USA-SPEC moet je uit de VS importeren, en zelf inbouwen. Als je niet bang bent voor kabeltjes is dat redelijk te doen
Oh, en de Volvo adapter heeft een haakse Melbus connector die WEL goed om zit
- Rogier64
Ik zal het allemaal wel niet snappen, maar de eenvoud hoe de originele Volvo iPod adapter werkt (playlists aanmaken is echt niet lastig hoor) en juist de veiligheid, lees onmogelijkheid om (tijdens rijden) te frummelen aan je iPod en te kijken naar het kleine display, heeft juist mij doen besluiten te kiezen voor de Volvo adapter.
V70 2.0D, MY2009 Prof. Tunex
V70 2.5 Europa, MY1998
Dat is ook heel de reden van Volvo het zo te doen, safety!
Ik weet dat het aanmaken van die playlists een eitje is, maar... Ik heb een eigen CD collectie van zo'n 1500 CD's en sorry, maar ik vind het te beperkt om met m'n iPod waar makkelijk enkele duizenden nummers op kunnen weer terug te moeten naar het tijdperk van 'maar' een 10-cd wisselaar...
Ik weet gewoon niet welke muziek ik naar wil luisteren de komende paar weken, en dat maakt het vullen van de playlists ook nogal tricky...
En zeer lovenswaardig, maar mijn voorkeur ligt, gezien de mogelijkheden bij de USA-SPEC adapter...Paul schreef:Dat is ook heel de reden van Volvo het zo te doen, safety!
.. ik laat mijn passagier wel de muziek uitkiezen
Is ook handig!
Tracks wel, maar geen naam van het Track
- interface
Juist, dat bedoel ik.
Dus als je niet weet onder welke playlist je bijvoorbeeld Jack Johnson hebt gezet, is het zoeken naar een speld in een hooiberg. Ik vind dat een behoorlijke gemiste kans van volvo. Sowiezo ook voor CD's, maar daar weet je wel welke CD je afspeelt, met 10.000-en nummers is dat andere koek.
Het heeft inderdaad een hoog zap gehalte
