Hi
I'm a Volvo owner from Finland and have bought my Volvo from Belgium. The only problem is that servicebook is Dutch and I can't a word Dutch. So please somebody translate following words to English.
1. Rubbers + steunen achtershockdampers ver
2. vervangwagen
3. afstandssteun
4. positielich
5. stationairregelklep
Please translate from Dutch to English
- menjo
1. Rubbers + supports rear shock absorbersmpsurf schreef:Hi
2. vervangwagen
3. afstandssteun
4. positielich
2. replacement vehicle
3. distance support?
4. sidemarkers (orange lights in the side of the car)
5. stationary (speed of engine without throttle engaged) adjustment valve
What did I win?
I should download the english manual, maybe you can check www.vvspy.com for futher information
- 480S60
5. stationary ===> idle?1. Rubbers + supports rear shock absorbers
Met vriendelijke groeten,
Arjen
Arjen
- Michael Oud
Yep, that's a better translation.
Volvo 940 SE
I would have still a few dutch words which are unfamiliar to me
1. Achterportierslot vervangen
2. Functionale Controle en testrit
3. Voorste motorsteun motorrubber vervangen
4. Motorophaning
Is Regelschuif and shockdemper same word and means shock absorber in english
Thanks
4. Motorophaning
Thanks
- FrankM
1. Replace rear door lock
2. Check functions and testdrive
3. Replace rubber of of forward engine support
4. Engine suspension
No: schokdemper = shock absorber, regelschuif = regulator (shift)
Note: it depends on what you are translating, "vervangen" can mean the active form ("replace something") but also the passive ("something was replaced"). So if you are translating the list of what should be done during a service job, it is probably the first form (which is written in the list above), if you are translating a report of a performed service job, you should read "1. Rear door lock replaced" (2,3,4 similar).
Good luck,
Frank
Good luck,
Frank
V60 T5 PS MY11 Sum+BPP+DSL+SL
S60 2.0T MY06 Sum
S60 2.0T MY06 Sum
