Onderdelen welke is best
Gesloten
Irishdude
Hello there
I am at the point of buying some parts for my Volvo xc90 T6 2004 and was wondering if anybody has experience or advice about which parts .
I asked the Garage what would it cost for them to do it and it was a bit expensive, and I am not scared of getting my hands dirty so I thought I'll do it my self.
I'll explain I have two lists of the parts I need one list is volvo parts and the other a list of similar parts but none volvo. but made to fit volvo by some place in Germany.
draagarm links
draagarm rechts
Fuseekogel
Fuseekogel
remschijf vooras
remschijf vooras
The none Volvo parts are cheaper that the Volvo parts,
Does anybody have experience using the cheaper none volvo parts or is goed koop duur koop :-)
thanks in advance
raymond_XC90T6
For brakediscs: use Volvo OEM, is my advise. I had a lot of problems with non-OEM's and it's a bad way to save because in the end, you're very likely to end up with the real deal anyway.
With non-OEM's I had problems ranging from uneven brake power, pulling the car to a side, to screeching and grinding noises.
volvo XC90 T6 MY2003 Pearl Black Exclusive 168.000 km - ? Geartronic 50.000km -?
Beige leer, moonroof, High performance audio, RTI 2014, PDC, stoelverw, inklapbare spiegels, Bi-xenon
Volvo XC90 V8 MY2009 Icy White 128.000 Miles
Beige leer, moonroof, High performance Audio, 7-seater, PDC, Stoelverw. Xenon, Rear Airco, BRC LPG installatie, Navigatie, Parrot MK9200, Elec.verst.stoelen voor
MartijnAbel
It's okay to use non oem parts, but use the better brands like ATE, Brembo etc. for brakediscs and pads. For the other items you want to buy, its best to use oem. What brand did you find for the fuseekogel and draagarm?
Musicus
Brake disk: ATE, same as OEM, but without the Volvo box.
Control arm and ball joint: Lemforder. Same as above, Volvo often uses this brand.
For more info look here (page is in dutch):
https://www.volvov70forum.com/topic.php?t=9235
S60 D5 2002, 850.000km
S60 2.4 2009, 282.000km
V40 2.0 2004, 264.000km
Irishdude
Thanks for the info so far , it confirms what I was already thinking about getting cheap parts, that they might lead to heartache in the end :-)
Laatst gewijzigd door Irishdude op 01.01.1970 - 01:00, 1 keer totaal gewijzigd.
Irishdude
The fusee and draagarm I found was merk Febi Bilstein,
I still need to double check the size of the disks 17 or 17.5 and so on
Hi Irishdude,
This is a Dutch language forum.
Please state your questions in Dutch only.
If you want information in English, please find an English language forum.
Gesloten
