Volvo V70 Bi-Fuel Necam system diagnostic wire
Geplaatst: 27.06.2007 - 10:12
Hello!
I have year 1999 V70 Bi-Fuel with factory mounted Koltec Necam LPG
gas system. On low rpm's (under 1000) running on gas engine cuts out. On standart
Koltec-Necam gas system has some diagnostic wire for system errors/
faults reading witch usualy is located under gas switch or under
passanger side dashboard, but at Volvo Bi-Fuel cars this wire/
conector is located/integrated in some another place. Who knows where
it can be found?
Thank you!
it can be found?
Thank you!
